Click for Burger Click for Northern Lights Click for Abeking Click for Westport Click for Walker
1st Gibraltar International Boat Show
Discussion in 'Boat Shows & Yacht Watching' started by Gibdan, Apr 17, 2009.
  1. Gibdan
    Gibdan Senior Member
    Gibraltar
    The 1st Gibraltar International Boat Show was held between the 8th and the 12th April 2009 at Ocean Village Marina in Gibraltar. Here are a couple of pics I took on the 12th.
    Daniel.
  2. Gibdan
    Gibraltar
    More pics.
  3. Gibdan
    Gibraltar
    more pics.
  4. Gibdan
    Gibraltar
    more pics
  5. Gibdan
    Gibraltar
    More pics
  6. Gibdan
    Gibraltar
    more pics.
  7. Gibdan
    Gibraltar
    more pics
  8. Gibdan
    Gibraltar
    More pics
  9. Gibdan
    Gibraltar
    More pics.
  10. Gibdan
    Gibraltar
    More pics
  11. Gibdan
    Gibraltar
    Last pics.
    Daniel
  12. Opcn
    Opcn Senior Member
    Great photos as always.
    A question/suggestion. Are you on a pc? If so you should get yourself IrfanView which is free. You resize your images to make them small enough to post here, and that is responsible for the graininess and stripe like nature of the diagonal lines. Since you are dealing with Jpegs which use vectors you can do something called resampling, where your computer draws the same vectors in to a smaller space, it takes a bit longer but you avoid those artifacts, and with Irfanview you can set up a batch transform, where you tell your computer to change all of the files and then walk off and make your self a drink and it does all the work one file after another. If not on a PC disregard this, I don't know how to do it on a mac or linux.
  13. Gibdan
    Gibraltar
    Thanks OPCN, I have already downloaded it and will play with it over the weekend.
    Daniel
