Hello All, I am looking at this vessel and can't seem to find out accurate information on the following: Favorable cruising speed with 7.2 MPI Merc's. Fuel burn at cruising speed. I really like the looks and layout of this boat and would like this info before committing. Thank you
Found this. Not the Mercs, but the same HP. Also included the specs for diesel. You'll note a substantial drop in speeds with the gas. That's a lot of boat to push with gas. I used to run a 370 with the crusaders. We cruised at 14- 17 kts @ 80% and had a range of about 111 nm if I remember correctly. That got a bit iffy running down to Florida in a couple of spots. Also, 19 year old gas motors may be getting a bit long in the tooth. Check the hours SMOH. Dimensions LOA: 40 ft 0 in Beam: 13 ft 3 in Length on Deck: 37 ft 1 in Maximum Draft: 3 ft 8 in Bridge Clearance: 12 ft 7 in Headroom: 6 ft 5 in Dry Weight: 21350 lbs Engines Total Power: 620 HP Engine 1: Engine Brand: Crusader Year Built: 1997 Engine Model: 454 XL Engine Type: Inboard Engine/Fuel Type: Gas/Petrol Engine Hours: 800 Engine Power: 310 HP Engine 2: Engine Brand: Crusader Year Built: 1997 Engine Model: 454 XL Engine Type: Inboard Engine/Fuel Type: Gas/Petrol Engine Hours: 800 Engine Power: 310 HP Cruising Speed: 19 mph Maximum Speed: 24 mph Tanks Fresh Water Tanks: (83 Gallons) Fuel Tanks: (297 Gallons) Holding Tanks: (35 Gallons) ============================================ Dimensions LOA: 37 ft 0 in Beam: 13 ft 3 in Maximum Draft: 3 ft 8 in Displacement: 20500 lbs Engines Total Power: 630 HP Engine 1: Engine Brand: Cummins Year Built: 1996 Engine Model: Diamond Edition Engine/Fuel Type: Diesel Engine Hours: 635 Drive Type: Direct Drive Engine Power: 315 HP Engine 2: Engine Brand: Cummins Year Built: 1996 Engine Model: Diamond Edition Engine/Fuel Type: Diesel Engine Hours: 635 Drive Type: Direct Drive Engine Power: 315 HP Cruising Speed: 28 mph Maximum Speed: 32 mph Tanks Fresh Water Tanks: (100 Gallons) Fuel Tanks: (300 Gallons) Holding Tanks: (35 Gallons)
I had a 1996 Carver 355--displacement was 18,000 lbs and it had twin 454 Crusaders. It got 0.88 mpg at cruise (3,000 RPM)
