Click for Abeking Click for Nordhavn Click for Northern Lights Click for Ocean Alexander Click for Comfort
1995 12v92
Discussion in 'Engines' started by william Hay, Dec 10, 2021.
  1. william Hay
    william Hay New Member
    Texas
    motor that spins but won't turn over and run? Issue?? Fuel? Air? Is a rebuild necessary anywhere in the picture? about 2200 hours
  2. boatpoor
    boatpoor Active Member
    Do you know the history of the engine? When was it last run? Was it shut down or did it shut itself down? Clean fuel in the tank and valves on?
    Make sure the e-stop hasn't been activated ( spring loaded flap on top of the blower, has to be manually reset if it was activated. What's the temperature there? Turn on the block heater if it's cold.
  3. william Hay
    Texas
    Shut down after run a couple of months back. Temp here in Houston is 70's. e-stop is fine. fuel seems to be fine. It's not too old.
    Are these DDEC engines or mechanical injectors?
  5. william Hay
    Texas
    DDEC. Im going to have DD expert check it out I just want to know what I'm getting into and what to expect. Also, to see if there is something I can do before I call them out.
  6. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    You mean when you push the start button nothing happens?
  7. Capt Ralph
    Hopefully you have a second set of batteries for the DDEC computers and controls, all breakers, fuses and wire connects are good and these batteries are up to charge also.
    If not a separate set of batteries, the cranking batteries, while spinning the engines may not give the computers enough voltage to keep running and they crash.
    Still check all breakers, fuses and wire connects.
    Check power going to DDEC computers and controls. But given the information given, it would be easier to consult a crystal ball. Just not enough info the give advice. Check the emergency shut down dampers (I can't remember if DDEC has them or not, all other DD's have them).
  9. Donzi 54
    Donzi 54 Member
    Point Pleasant, NJ & Morehead City, NC
    Check the shutdown button and make sure it is not stuck on.
  10. Lunderic
    Lunderic Member
    Oceanside, NY
    Check Shutdowns from fire system if you have one installed. They fail fairly often...
