Click for Abeking Click for Abeking Click for Burger Click for Westport Click for YF Listing Service
1991 45" Viking aft rail question
Discussion in 'Viking Yacht' started by vds1968, Jan 3, 2021.
  1. vds1968
    vds1968 New Member
    point pleasant beach NJ
    I have 1991 45' Viking with cummins qsm 11 i am thinking about installing lift rails/ Is it worth it?
  2. vds1968
    vds1968 New Member
    Sorry Lift rails
    I ran one 45' with them, had 6v71's and ran well. I do not know if the lift rails were the reason why......
  4. NYCAP123
    What are "lift rails"?
    Like a spray rail, but they're alongside the hull on the edge where the hull meets the hull side. Kind of concaves downward a bit. Some manufacturers added them at the factory to fix a hull design that didn't run as stable as expected at cruise speeds.
    Like this:
    48rollchock-jpg.77029 (800×600) (yachtforums.com)
  6. NYCAP123
    Oh ok. The way it was phrased I thought the OP was referring to something with the motor. Spray rails are common, but I can't see them having much effect on lift, no matter how angled, over what the trim tabs and chines designed for the hull do.
  7. RER
    RER Senior Member
    Newport Beach CA
    lol ...that's my photo of a 48' sportfisher hull that had been extended 4' from an original 44' a 15' hull. And yes it did help with stability and lift in this case.
    I notice that they help with stability and lift also......
  9. bayoubud
    bayoubud Senior Member
    Florida
    I owned a 1989 Viking, what is happening t0 make you want to add lift rails.
  10. vds1968
    vds1968 New Member
    Sorry lost user name and passwords I’m back now
    So I made and installed lift rails well worth all the effort
    Boat is much drier picked up a little speed and the engine load is less
    FL000 likes this.
