Click for YF Listing Service Click for Furuno Click for Cross Click for Abeking Click for Walker
1987 Symbol 59'
Discussion in 'Symbol Yacht' started by Joel Smith, Jan 30, 2022.
  1. Joel Smith
    Joel Smith New Member
    San Diego
    I am looking at a Symbol that has (3) CAT 3208's . I have owned Hatteras 68 and other large vessels but triple power is new to me. Any comments would be appreciated.
  2. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    What hp are the 3208’s ? If they are the higher hp version be wary.
  3. Joel Smith
    San Diego
    375HP
  4. mapism
    mapism Senior Member
    Sardinia
    I believe the version Dockmaster suggested to steer clear of is the 435hp.
    If properly maintained, the 375 are solid enough, instead.
    Out of curiosity, I googled for such boat, assuming that there aren't many around.
    In fact, I guess this one which I found in half a minute is the one you are considering:
    https://www.atomictunayachts.com/product/1987-symbol-motoryacht/
    If so, she looks fantastic for living aboard.
    I'd better not show that galley to my wife, 'cause she suddenly wouldn't be happy with ours anymore!
    But I must say that her engine room, and particularly the central engine installation, is puzzling - see below.
    Was she possibly designed to run on the central engine alone at displacement speed?
    [​IMG]
  5. DOCKMASTER
    Ketchikan, Alaska
    The 3208s are good engines. As with any engine, when you continually push the hp higher problems can arise. With 3208s they really pushed the envelope in later years of production. Certainly the 435hp version fall into this category. Some would say the same of the 375 hp. The 320 hp and lower were known to be pretty reliable. The ad says 1100 hours; is that correct? That is very low hours for a 35 year old boat. Make sure you do a very thorough survey. As the saying goes, if it rests it rusts. That's a lot of resting in 35 years.
  6. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Three engines ? How come ?
  7. Capt Ralph
    Only one gen-set????
  8. Capt Ralph
    One for going real slow. All thee for going not so slow.
  9. cleanslate
    Cherry Hill, NJ
    I can do that with my twin screw vessel and my single screw vessel. Just use the throttle. o_O Sounds like one more headache to worry about.
