Click for Furuno Click for JetForums Click for Mulder Click for Mulder Click for Nordhavn
1984 catalina 280 transmission
Discussion in 'Chris Craft Connies, Commanders & Catalinas' started by joe marshall, Dec 6, 2021.
  1. joe marshall
    joe marshall New Member
    Fl
    Anyone know what transmission is in the 84 Catalina 280?
    Paragon, Borg, Chris, others...
    Should be a tag on it.
    If not, send us a picture.
  3. joe marshall
    Fl
    I believe it to be a zf i just dont know what one
    ZF? Maybe, but unless it was re-powered, it may be to old of a boat for a ZF.
    There are tags on ZF clutches also.
    What engine?
  5. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Hurth or Borg Warner velvet drive
    What Captain Ralph said also.
    Highly doubt it’s a ZF.
  6. joe marshall
    Fl
    It looks like the zf pics i have seen online and looking at the stringers it looks like there may have been something different at some time ill be at the boat sunday and ill take pics
  7. Capt Ralph
    ZF took over Hurth a ways back.
    Some cases are the same, some were dropped. Lots of model numbers were changed on the surviving cases.
    Unless the boat was re-powered with a newer setup, from 1984 on a chevy V-8 was usually Borg or Paragon.
    Please send pictures of the gear, engine and all tags.
  8. joe marshall
    Fl
  9. cleanslate
    Cherry Hill, NJ
    I knew that...I knew that..:rolleyes:. CR, you gave me another lesson.
  10. joe marshall
    Fl
    So any idea what trans it is?
  11. Capt Ralph
    FM, that is a ZF clutch.
    Series 25 thru 45A.
    Find the tag on the clutch and call a ZF Marine shop for the correct model number.
    Later Chevy small block.
    Vortec heads and intake manifold.
    Not original engine package.
    I remember looking at this sad package before. Thought (hoped) we talked the guy out of it.
  12. cleanslate
    Cherry Hill, NJ
    As we say in Philadelphia… “ My man….”
    CR.
    Done figured out deal.
    Op , good luck with your boat.
    I hope it works out for you.
    sea trail ….sea trail…make sure it works. In the water sea trail , btw .
  13. joe marshall
    Fl
    Whats so sad about it
  14. joe marshall
    Fl
    The boat ram great before it sank and it only sank do to dead batteries
  15. joe marshall
    Fl
