Click for Westport Click for Glendinning Click for Burger Click for Perko Click for Abeking
12 v 92 coolant issue
Discussion in 'Engines' started by bluesuit, Feb 17, 2014.
  1. bluesuit
    bluesuit Member
    new orleans
    Dear All:
    On cold engine I attempted to check coolant level of expansion tank. When I open the radiator cap coolant came spewing out under some pressure. What y'all think????
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Expansion tank cap stuck?
    Over flow tube from the expansion tank cap to the coolant tank blocked?
    Head gasket issue?
    The cap is doing it's job if there still is a little pressure in the system when the engine is cold. I've seen this happen on engines with overflow bottles. If there's a lot of pressure than I'd start worrying.
    Put the cap back on, walk away, dream of warmer days.
    Some time earlier, the block was colder than when you opened the cap. Just a couple of degrees caused the expanding coolant to roll out.
    Should of happened to both mains. If not, replace the caps on both next ER visit.
    ,rc
  5. RB480
    RB480 Senior Member
    New Buffalo, MI
    I had this happen on our 892's. Turns out the port engine had a kink in the expansion tank hose. New hose and it's back to normal.
