Click for YF Listing Service Click for Northern Lights Click for YF Listing Service Click for Westport Click for Glendinning
Feature: Benetti 77M 'Se77antasette' Concept
Discussion in 'Benetti Yacht' started by Yacht News, Sep 29, 2017.
  1. Benetti 77M 'Se77antasette' Concept
    Benetti Yachts released a concept on the eve of the Monaco Yacht Show (MYS) called the 'Se77antasette'. Benetti, in an exclusive partnership with designer Fernando Romero, one of the world’s most influential architects and famed for his high-profile civil projects, premieres the innovative Se77antasette concept yacht at the 2017 Monaco Yacht Show. Visually, this dynamic union between decks creates a single body that seems carved into the structure of the boat, offering original spatial proportions that enhance the close relationship between nature and the sea.
  2. The master suite on the Se77antasette, situated in the forward area of the main deck, is a 100-square-meter apartment, plus 140 square meters of private outdoor space to enjoy in complete seclusion. Inside there are plans for a hi-tech studio/office to stay connected from anywhere in the world. The made-to-measure wooden bed is situated in the center of the room, with sofas on either side and a walk-in wardrobe. The large marble bathroom has a view of the sea and private shower and toilet rooms. The terrace in the bow is furnished with comfortable sofas and even has a private 1.5-meter deep swimming pool. The space is also equipped with a floor lifting system that transforms it into a heliport to land and take off. Guest accommodation is in two VIP-grade cabins as well as four other cabins all on the lower deck.
  3. The internal spaces feature wide open areas characterized by the use of high ceilings and extensive utilization of glass. The main salon is the perfect depiction of this scenario. It isn't often soaring ceiling heights and grace a main saloon even on 77-meter yachts. Bare in mind, this is a concept but it just shows what direction some designers are willing to push the penned narrative in. Teak, glass and neutral to light tones create a sense of openness.
  4. The beach club is also another area of expanse where the interior becomes almost one with the nearby ocean. The beach club opens up on three sides via two side doors as well as a transom door. There is a large pool centrally placed that is enormous enough to truly comfortably swim in without reservation. There is enough space left on either side for a plethora of deck furniture to be placed.
  5. 77-meters long and 14.20 meters wide, it will be fitted with 5 variable speed Caterpillar generators, 4xC32 (1048 ekW @ 2300 rpm) and one C18 (563 ekW @ 2100 rpm) coupled with two twin counter-rotating screws pods (1700kw each) driven by permanent magnet motors. The variable speed generators allow the use of the full power available from the diesel engine and in addition requires less space in the engine room. Another advantage of the variable speed generators is the efficiency in sharing loads through the various operational modes (cruise, anchor…). This power flexibility allows lower exhaust emissions. The propulsion system delivers a top speed of 16-knots and a range of 5,000 miles at 12-knots, and welcome up to 12 guests on board, with accommodation for 19 crew members on the lower deck.
    Azimut | Benetti S.p.A.
    Via Michele Coppino, 104
    55049 Viareggio
    Italy
    www.****************
