Click for Nordhavn Click for YF Listing Service Click for Mulder Click for Walker Click for Nordhavn
Salon Overhead Lights
Discussion in 'Ocean Yacht' started by Tashmoo, May 22, 2017.
  1. Tashmoo
    Tashmoo New Member
    Cape Cod
    Anyone know where I might find replacement trim ring for the overhead flush-mount downlights in Ocean salon? No mfr name anywhere. They're 2-3/4" plastic trim rigs for the original halogen lights.
    Mod edit: Oversize image removed.
    There should be a manufacturers sticker on the assembly the trim ring fit's onto. Check that.
  3. justold
    justold Member
    new jersey , fla
    picture please
  4. Tashmoo
    Tashmoo New Member
    Cape Cod
    SMALLER
  5. Pascal
    There should indeed be some label on the fixture itself, probably on the top side. If older it may be hard to find it. Plastic covers are rare on these fixtures
    You may have to replace the fixture(s) in a room with just one of or two lights so you can use the cover to match those in the salon
  6. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Might be DRSA brand, "Mako" model. Search on that and compare.
    If so, have heard they don't sell just the trim rings any longer... but the whole fixtures aren't hugely expensive.
    -Chris
  7. Pascal
    DRSA fixtures are/were used by a number of builders but I've always seen solid stainless fixtures, not plastic although they may have had them
  8. ranger58sb
    Chesapeake Bay, USA
    Yep, the Mako fixtures have a plastic bezel. Cayman Brac (something like that) are "brass." Happens we have both, in various places. Near as I can tell, the only difference in ours is the bezel.
    I can't tell perfectly whether OP's bezel are DRSA/Mako or not... ours are "whiter" than that...
    -Chris
  9. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
  10. d_meister
    d_meister Senior Member
    La Conner, WA.
    Cantalupi was the big name in interior lights for a time, maybe even the original mousetrap light. Everyone carried them, including West Marine, but they've pretty much disappeared from display real estate. It may have something to do with the advent of LED's. Cantalupi is still available on the net.
  11. Prospective
    Prospective Senior Member
    New England
    Keep us posted with what you find. I have the same and many of mine are cracked on my '43. I have replaced fixtures in the guest SR and both heads and salvaged the trim rings to put elsewhere. But replacing fixtures is expensive and a PIA. Replacing bulbs and trim rings would be cheaper and easier.
