Click for Mag Bay Click for Nordhavn Click for Nordhavn Click for Furuno Click for Northern Lights
no water in toilets
Discussion in 'Carver Yacht' started by jeff f, Jun 9, 2016.
  1. jeff f
    jeff f New Member
    brockville ontario
    Hi, new member here, I have just purchased a Carver 350 AC with Raritan electric flush toilets and they do not store any water in the bowl. I have heard that this may be normal for these toilets but it doesn't seem right, the water just goes straight to the tank. Also there is no room for a vented tube. Anyone have this issue? Thanks in advance,. Jeff
  2. olderboater
    Have you looked in the manual for the unit you have?
  3. jeff f
    jeff f New Member
    brockville ontario
    I have but no mention of this.
  4. NYCAP123
    Is this a raw-water system? If so it's normal. Salt water or low tide water stinks.
    The vent should be near the tank.
  5. Bill106
    Bill106 Senior Member
    Beaufort NC
    Which model do you have? The most common model (at least what I've seen), the Atlantes has an internal vent cap that for downhill discharge plumbing needs to be removed to leave water in the bowl. It could also be a clogged vented loop flapper (if installed) on the discharge causing a siphon that empties the bowl after flushing.
    Some of the newer heads can be programed on the remaining water.
    I just learned this on a Tecma system.
  7. olderboater
    It would help to know the model number and whether it's fresh or raw water.
  8. jeff f
    jeff f New Member
    brockville ontario
    I am not sure of the model, will have to check when I go back. There is no vented loop, just a straight discharge hose to the tank.
    I think I have a parts diagram on board, thanks for the reply.
  9. jeff f
    jeff f New Member
    brockville ontario
    Not sure of the model and it is on raw water.
  10. Capt J
    Yes, I just installed 2 new Marine Elegance toilets on fresh water flush, and they don't normally store water in the bowl after flushing unless you hit the fill button.
  11. bobhorn
    bobhorn Member
    Kemah, TX
    We installed one several years ago and it always leaves water in the bowl, fresh water flush or raw water flush. Depending on the flush water pressure there are some timer adjustments that can be made that determine for how long the flush water runs.
  12. MAV
    MAV New Member
    Ontario, Canada
    It would help to know the model or at least the year of the boat. If it's a Crown model, it will leave a little water in the bowl but not much. When you push the button, the same motor activates both the discharge and raw water impeller at the same time. So while the raw water impeller is bringing water in to help drain the solids, the discharge impeller is evacuating the solids and water that's coming in. The reason there is a little water left in the bottom (very little) is because as with any impeller driven pump, as soon as it starts sucking air, it also stops pumping fluid effectively.
