Click for Delta Click for Westport Click for Mag Bay Click for JetForums Click for Abeking
News: Sossego Yachts Launch 22M "Falcon VII"
Discussion in 'Yacht News; Builds & Launches' started by Yacht News, Aug 16, 2015.
  1. 22-meter "Falcon VII" Launches At Sossego Yachts
    Dutch builder Sossego Yachts is proud to have launched the 22-meter all-aluminium Comfort Class called "Falcon VII". The design is by Mulder both inside and out. The yacht is semi-custom allowing the owner to customize some aspects of the boat. The standard engine set-up for this yacht is twin MAN 1200 HP marine diesels. However, there is an optional set-up for twin MAN1550 horse power should an owner choose a more powerful pairing.
  2. Falcon VII has two full decks -lower and main- along with a large open-air sundeck served by a dedicated stairs from the main deck. There is plenty of seating and sunpad region in conjunction with further sunbed seating on the foredeck. The main cabin onboard is the full-beam master suite which is located just aft of midships. It features large windows on either side with ensuite bathroom. There are up to three other cabins that are available to guests. There is a large swim platform that will be home to the main tender. However, you can launch it and then have the full square-footage available for watersport connections. Look out for Falcon VII when she is on display at HISWA in-water BoatShow which will run from September 1 to 6th 2015.
    Gebr. van Enkhuizen
    Stranwei 11
    8754 HA Makkum
    www.gebrvanenkhuizen.nl
