Click for Delta Click for Ocean Alexander Click for Perko Click for Glendinning Click for Nordhavn
News: SanLorenzo Secures Owner For 64M Flagship
Discussion in 'SanLorenzo News & Launches' started by Yacht News, Jul 22, 2016.
  1. SanLorenzo 64-meter Flagship Under Construction
    Italian builder SanLorenzo is building even larger now with a 64-meter superyacht that will naturally assume flagship status for the yard once completed in a few years. The yacht will be very roomy as well boasting a 1,500 GRT figure. The superyacht has started construction at the yards new La Spezia facilities and appeared to have done so on spec (that's unconfirmed). However, recently the yard has found an owner for this record-breaking (for the yard) project.
  2. The 64-meter yacht rises four decks out of the water still keeping many of the design values and traits that can be found on the smaller STEEL series. One thing we notice is that the tender garage is situated midships which likely means that SanLorenzo is continuing with the beachclub theme in the transom. Many details are not known about the build as yet. The top speed is anticipated to be around 17-knots for this particular hull. Delivery is slated for 2019 to her new owner. Below is a render of the SanLorenzo 52 STEEL to compare with the above photo of the 64-meter.
    San Lorenzo SPA
    Via Salvadori, 58
    55049 Viareggio
    Italy
    www.*******************
