Click for Nordhavn Click for Furuno Click for Mulder Click for Glendinning Click for YF Listing Service
News: Ocean Alexander 34M "Sugaray"
Discussion in 'Ocean Alexander News & Launches' started by Yacht News, Dec 23, 2017.
  1. Ocean Alexander 112 "Sugaray"
    The Ocean Alexander 112 is a result of a stepped-up approach from Evan K Marshall and Ocean Alexander. With an LOA of 112-feet, a BOA of 24.6-feet and a draft of 6.3-feet "Sugaray" is quite spacious for a yacht just over 100-feet. She is also small enough to access pretty much any marina or close in to bays and coves. Typically, vessels of this size are tri-deck, this one has four decks. A lower deck is where most of the accommodation is located, the main deck is where the formal entertainment can take place, the bridge deck or what some may call an upper deck is more informal entertainment and the sundeck is all about relaxation.
  2. The interior is finished in a contemporary flair with parquet-styling taking prominence through out the interior. There appears to be a five-cabin layout with two doubles and two twins on the lower deck and a split-level master on the main deck with bathroom down one level below. Crew quarters are likely towards the stern aft of the engine room. Below is an example of the master and the detailing of the concept.
  3. The Ocean Alexander 112' carries a pair of marine diesels and fuel capacity of nearly 21,000 LT. Fresh water storage is up to 4,013 LT. The 265,000 lbs yacht has several special features including a jacuzzi on the sun deck, tender storage on the aft upper deck, fold-out balcony bulwark on the port side to further aid outward views from the formal dining room space. The guest cabins have oversized windows to help keep the connection with the outdoors going. Sugaray is available for charter this winter down to the Bahamas!
    Ocean Alexander
    www.oceanalexander.com
