Click for Comfort Click for Abeking Click for JetForums Click for Westport Click for Burger
hatteras liveaboard??
Discussion in 'Hatteras Yacht' started by Wl3175, May 30, 2015.
  1. Wl3175
    Wl3175 Member
    Newport RI
    We are considering moving onto a boat to live .We both have extensive knowledge of boats and work in the Marine industry but not much about a good live aboard would a Hatteras be a good option .no bigger than 65 to 68 ft ,3 staterooms and a nice sized living area ,most lkely on the west coast initially
  2. olderboater
    Hatteras MY's in the 50-60' size range make excellent live aboard boats. They are solid, have excellent room and generally are well equipped and laid out. However, there are other factors in boat selection. One of the first that would come to my mind is your intended use when leaving the dock. How important to you are things like fuel economy and speed. The Hatteras will typically have the speed at the expense of fuel economy but can be run at displacement speeds economically, just never as economically as a lesser powered boat designed as displacement.
    Most Hatteras you find in the 60-70' range are SF or Convertibles, rather than MY's but there are a few MY's. SF's simply don't have the live aboard space of their MY's, although they have other attributes, especially if one is a fisherman. There are a few 65's of 1989 or so vintage out there. Hatteras has a long pattern of building sizes the getting away from them then coming back to them.
  3. Wl3175
    Wl3175 Member
    Newport RI
    Thanks for the reply answer to your question about leaving the dock fuel efficiency is important .We intend to cruise long distance at some stage and wont be in a hurry so speed is not a big issue . We are open to suggestions on boats makes and models we just liked the space the Hatteras has to offer in that size range .I would love a huckins yacht but the whole wood aspect i am not interested in anymore
  4. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    If you do look at a sport fish then a Roscioli Donzi 65 should be first on your list. It's far larger on the inside than a comparable Bertram, Viking or Carolina boat. Hatteras is a very wide boat and thus may present difficulty in finding a slip sometimes. Donzi's have smaller staterooms and more salon space and monster second deck. Good luck with your search.
  5. olderboater
    What age and price range are you searching in?
  6. Wl3175
    Wl3175 Member
    Newport RI
    we would like something late eighties upwards and a price range of approx $500,000
  7. olderboater
    That works for a late 80's, 63 or 65' Hatteras MY. One problem you do encounter is they are mostly east coast, but I saw a couple listed in Seattle.
    Bamboo is obviously a Donzi owner and fan. I'm a Westport and Pacific Mariner fan so will point out one boat to also consider and will get you a bit newer boat. That's the Pacific Mariner 65. Now, it's not stylish and many do not like the exterior look. I'm not a huge fan of that myself. But it has space and amenities and good performance.
    There are also some Ocean Alexanders that fit your specifications. I wouldn't rate them at the level of Hatteras or PM but many owners are happy with them.
    Then some Azimut, which generally won't get good ratings here. However, a boat that's had the problems addressed and does well on a survey might be worth it.
    You may also find you need to go a little older or a little smaller. I don't know if your $500,000 includes upgrades, etc. that you need to make up front. I certainly think within your range though you'll find a good boat for both living aboard and cruising.
  8. Wl3175
    Wl3175 Member
    Newport RI
    looked at a pacific mariner and agree exterior wise not the best looking but amenities are pretty good. not interested in Azimut i have seen many of these boas and all seem to have problems and having worked on a few chasing wiring it was an absolute nightmare .The price tag may be a little low for what we are asking for but we are not opposed to spending a little more upfront for a better boat or upgrades
    i know nothing is perfect and it being a boat look the wrong way and something goes wrong. luckily i can do most things on a boat except any major engine work
  9. NYCAP123
    Prior to this winter's layup I've spent about 2 weeks a month living aboard a 1981 56 MY, and I can tell you that they're very comfortable. I sleep in the VIP. The Master is real nice. They lend themselves to cosmetic refits very well, and have a ton of separated spaces and entertainment areas.
    You might find this useful:
    Dimensions :
    LOA: 60’
    LWL: 56’ 3”
    Beam: 18 ft 2 in Minimum 19 ft. minimum slip
    Draft: 4 ft 11 in
    Bridge Clearance:
    37 ft. to tallest mast
    26 ft. to masthead light
    18 ft 10 in to windshield
    Dry Weight: 74,000 lbs
    Headroom: 6 ft 8 in
    Engines: Engine Brand: Detroit Engine(s) Total Power: 1300 HP
    Engine Model: 892 TI Engine Type: Inboard Drive Type: Direct Drive
    PERFORMANCE ESTIMATES (the numbers will be a bit mushed together. DK why, Let me know if you can't straighten them out and I'll PM the infor to you):
    Rpm Speed Knots Fuel Cons. Fuel Cons.E & G Range NM Engines. Engines & Engines& Gen
    550 Idle
    1200 9.3 12.5 14.0 707 631 economy
    1500 11 21.7 23.2 536 501
    1800 12.1 35.0 36.5 385 369 cruise
    2100 14.6 53.5 55.0 322 313
    2300 17.1 70.6 72.1 283 277 WOT
    Tanks: Fuel Tanks (2) fore and aft: (1020 Gallons total)
    Fresh Water Tanks: (350 Gallons)
    Holding Tank: (60 gallons)- pump out at stbd gate
    Generators: 20 KW Kohler Genset
    12.5 KW Onan Genset
    Electrical: 32 volt ship service electrical supply with vapour proof master switches, master breakers and tabulated and fused distribution panels.
    32 volt engine starting system. 12 volt electronics circuit. Sentry 32 volt charger.
    112/240 volt dockside power system with shore cord, inlet fitting, master breaker and tabulated and fused distribution panels
  10. Wl3175
    Wl3175 Member
    Newport RI
    thank you NYCCAP123 for this information Very useful will spend sometime tomorrow looking at your number in more detail but first look seems about what I was expecting in fact better than I thought
  11. olderboater
    As Nycap's example points out, you might find what you're after in a slightly smaller boat than you initially thought. You need to think how you'll be using it, how many aboard. I'd plan for the 95% or 98% usage. Don't get a boat designed for that very rare occasion. For that someone can sleep in a salon or in a hotel room or anything it takes. Most families have experienced improvising sleeping arrangements when everyone is there.
  12. RB480
    RB480 Senior Member
    New Buffalo, MI
    Willy, as you are aware I know these boats well and spent the entire winter living aboard a 1984 56' Hatt Motor Yacht. I find as they get larger you mostly only gain main salon space and another stateroom.
  13. Wl3175
    Wl3175 Member
    Newport RI
    Ray completely forgot about you living on one .pity your one is not on the west coast it would be a perfect boat for us
  14. revluc
    revluc Member
    Gulf Coast
    I agree with oldeboater on the Hatteras inventory being thinner on the west coast. Another brand you might consider (I am a bit basis as one of our boats for 25 years has been a Tollycraft) is a 57' or 61' Tollycraft. A west coast brand and the vintage/price range would fit what you are considering. The Tollycraft or Pacific Mariner you are trading out salon space for having a cockpit compared to the Hatteras. Do you want/need a cockpit? Dropping some lines in the water or to help with docking?
  15. Pascal
    It s hard to beat teh Classic hatts as a live aboard and they come in various size and vintage/budget.
    Ou could also look at some of the 90s viking motoryachs
  16. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
    We, a middle aged couple lived aboard and cruised 12,000 miles on a Hatteras 56MY full time for 5 years, and part time for another year and a half. It was extremely comfortable and we liked it better and better as the years went on. I was so glad we bought a Hatteras. The support from the factory and the spin off of their parts department, Sam's Marine (who also sponsors an excellent owner's forum) is outstanding, even for 30+ year old boats. The boat was easy for a big klutz like me to work on and get around in. The ergonomics are outstanding, even I could single hand it. We looked at larger boats and just didn't see what we would gain by it, save for the 61CPMY which was our boat with a cockpit. But as it turned out we did fine without the cockpit, and the 60 foot LOA mark is a dividing line for a lot of moorings and slips.
    One of the wisest aphorisms in boating is "don't buy the biggest boat you can afford; buy the smallest boat YOU can be comfortable in". What that is, is a very personal decision. I know happy couples who did what we did on 36 footers.
  17. hogwash
    hogwash New Member
    virgin islands
    i was wondering while being away from the dock and at anchor how long do you run your generator each day and do you run both of them.
  18. Caltexflanc
    North Carolina
    We put an inverter and dedicated battery bank on our boat. So unless the weather was very hot or cold, we just ran the generator a couple hours or so in the morning and then again at night for battery charging, cooking, laundry, dishwasher. One 20kw genset could power everything.
  19. hogwash
    hogwash New Member
    virgin islands
    thanks- most of my experience was tethered to the dock on an old chris craft but now my wife and i are looking for the right 70' hatteras for live aboard life in the virgin islands.
  20. Capt J
    The Hatteras are very economical at hull speeds, just as much as a same size trawler. The 2 cycle Detroits sip fuel at 1000 rpms or below. I did the entire great loop in a 75' MY (65' stretched to 75'). At 1000 rpms we burned 12-13GPH (15gph with generator, we always ran the generator) at 10.3 knots, we held 1650 gallons of fuel.
    I did 5300NM's on the Great Loop, ran cruise at least for 30 mins every 6 hours, and also for 2 full days of the loop. We anchored 3 out of 4 nights and ran the generator 24/7. I burned just under 7500 gallons, not bad for a 75'.
    I think you could be very comfortable in a 53'-58' Hatteras. I'd recommend 1987 or newer as they were 24 volt boats instead of 32 volts. I know we have some 32 volt fans here, but parts are getting harder and harder to find and choices on some items such as battery chargers, heads, etc. are limited. The Viking widebody MY's are also a good liveaboard choice as would be some of the Lazzara's from late 90's.
    Yes you could add an inverter and a ton of batteries (and weight) and only run the generator during prime usage. If you're not using heat/air, then your electrical load probably won't be too bad......but honestly, to me that's camping and not yachting. If you can't afford to run the generator while on the hook, count me out.
    1 generator should cover everything on the boat 98% of the time. If you plan on having all a/c's cranking, washer/dryer going and oven then you either have to shut a few items down temporarily or run 2 generators.
