Click for Ocean Alexander Click for JetForums Click for YF Listing Service Click for Mulder Click for Burger
Elco 53 boat
Discussion in 'Vintage & Classic Yachts' started by Tranquilein53, Jul 7, 2017.
  1. Tranquilein53
    Tranquilein53 New Member
    Florida
    Hello guys: I have a friend that owns a Elco 53ft that I believe is been cold molded. Can that boat be haul out with a regular travel lift with slings? And what will be the anount of "safe" days that could be out of the water before planks starts shrinking? Thanks
  2. Pascal
    If really cold moulded, drying isn't an issue as there are no planks. The wood is basically just like a core or cloth
    Now if planked then yes you will need to let the wood swell upon launch.
    Completely different constructions. Words like "I believe" are pretty scary when asking for free internet advice
  3. Tranquilein53
    Florida
    Hello Pascal: that's what his been told that she was "cold molded" the hull outside looks really "sleek " you can't tell is a wooden boat. Does she need a special haul out? Thanks
  4. Tranquilein53
    Florida
    ps: I'm pretty sure you helped me a lot when I used to own my Hatteras 43DC 1974 a few years ago
  5. SeaEric
    SeaEric YF Historian
    out on the dock
    Properly executed, a "cold molded" sheathing over the original antique wooden hull should make her fair, dry and quite stiff. A travel lift haulout should not be a problem. It would, however be important to know her true structural condition before proceeding. If what's under the "cold mold" application is stucturally compromised then disaster could be just around the corner. As always - YMMV.
  6. Tranquilein53
    Florida
    Thanks, I will let him know to investigate this more.
  7. Capt Ralph
    Where is the boat getting hauled? A better yard will go aboard and check these items out.
  8. riptidecrew1939
    riptidecrew1939 New Member
    Port Orchard, WA
    Where is the Elco located? I have the same model in Washington state.
