Click for Burger Click for Delta Click for Nordhavn Click for JetForums Click for Glendinning
Davit Parts/Service
Discussion in 'General Yachting Discussion' started by Frankster, Apr 13, 2025.
  1. Frankster
    Frankster New Member
    Sausalito, CA
    I recently purchased a 2001 Riviera 43 with a davit for the tender. The davit is a Quick Lift Davco 350 kg. It is not operational in the manual or remote mode. Reservoir is full, motor works and the lines seem good. When operated in the manual mode, the motor/electric pump runs continuously but no movement with the davit.
    Any help would be greatly appreciated.
  2. Pascal
    Quick lift is out of business. In manual mode you have to start the pump manually by connecting the wires in the base of the davit and then you have to either push or pull (I don’t remember which) the valve for the function you want to activate. This allows you to bypass the remote which is usually the failure point.
