Click for Mulder Click for Mag Bay Click for Nordhavn Click for Mulder Click for Glendinning
Cold Molded Rybovich
Discussion in 'Rybovich Yacht' started by Ricochet, Jul 18, 2010.
  1. Ricochet
    Ricochet New Member
    Stratford, Ct
    Any thoughts/first hand experiences on how well a cold molded hull is suited to the northeast US climate ... heard that the different coefficient of expansion of the encapsulated wood vs. glass/resin could potentially lead to hull cracking over a period of time ... thanks
  2. Ricochet
    Ricochet New Member
    Stratford, Ct
    Rybovich sea keeping
    am hearing that Rybovich SF are not good head-sea boats and will pound ... any comments?
  3. CaptPKilbride
    CaptPKilbride Senior Member
    On the water
    Cold molded
    I take care of a cold molded sailboat with a jet black hull, no problems other than print-through, which is to be expected and will not be an issue after the next spray job.
    I wouldnt anticipate a Rybovich would have any of these issues you are concerned with.
  4. Seafarer
    Seafarer Senior Member
    Hudson River
    We had a cold molded 1955 Huckins that we brought up from Texas in 1961. It's still in Connecticut to this day. Plenty of other cold molded boats in the northeast as well. This includes Ryboviches of virtually all age.
    It's all in how you maintain it. That is, if you don't maintain a boat, eventually it will fall apart no matter what it's made of.
    I haven't experienced (significant, excessive, or abnormal) head-sea pounding in a Rybovich up to 9-10' (3 meter) seas. I suppose if you're on a 4X-foot boat trying to run 30 knots head on into 4' chop on top of 6' rollers, you might beat the boat apart, but that might be true of just about any small boat.
    Where had you heard these pieces of "information?"
  5. Ricochet
    Ricochet New Member
    Stratford, Ct
    Seafarer, ...
    an opinion shared by some charter professionals that I have no reason to distrust ... from your response, do you or did you own a Rybo and are sharing your personal experience as to her performance ... just trying to solicit as much detailed info from as many users as possible to help make the right decision and not second guess ourselves later on.
    Thank you so much ... really appreciated
  6. Seafarer
    Hudson River
    We had a Rybo for a season (not the one in my avatar). There are a lot of other boats that pound harder. Rybos aren't heavy slugs, so they won't just plow through waves, it's true. But pounding excessively? Not in the 50' range at least.
  7. Ricochet
    Ricochet New Member
    Stratford, Ct
    Thanks, Seafarer ... could you briefly relate your "likes" & "dislikes" ?
  8. saltysenior
    saltysenior Senior Member
    stuart,fl.
    do you realize that every rybovich is different ???
