Click for Northern Lights Click for Perko Click for Nordhavn Click for Mag Bay Click for Abeking
Can a retired Airman own a yacht?
Discussion in 'Hatteras Yacht' started by Retire2Cruise, Sep 15, 2015.
  1. HTMO9
    HTMO9 Senior Member
    Ritere2Cruise, if you have been stationed in Ramstein or Spangdahlem, you will find the weather and the culture at and around Kadena AFB quite different. The Steaks are pretty expensive off base. In the mid eighties there were a lot of jokes going around in the US Air Force about those gay F-15 pilots at Kadena. The F-15 drivers took a lot of Sh..... at the bar in the officers mess all around the world at that time :).
    But when being relocated to the continental US for your last assignment before retiring, I would concider buying, what the specialists here on YF call, a project. With your technical education and skills, you should be able to do almost any type of major overhaul and renovation on a 50 to 60+ ft yacht. And this inside, outside and for the complete machinery. Given your long timeframe of 10 years and buying a low priced hull but worth being renovated, could save you a lot of money. Personal labour will cost only time. And the long time frame would allow you buying parts and material as available money permits. And this forum is the greatest base of knowledge and advice any do it yourself could find.
    In Europe, we have several companies and associations which provide plans for self building kits with some additional support in training and advice and even prefabricated parts. With aircrafts it is called homebuilts, with boats most likely the same. I am sure something like this exist in the US too.
    I like your idea, very realistic approach. A man must have a dream. And I can tell you, I still miss my first life in the Air Force. But I was never good enough to be a technician, with my two left hands, I could only become a pilot :p. Enjoy your tour.
  2. K1W1
    If you do attempt this please video it to entertain the rest of us.
  3. Pascal
    Nah... Bimini? I d suggest the Bimini Destroyer... Oops sorry... The bimini Superfast :)
    Juste kidding... My point is that as a yachting destination key west and the keys are just very limited.
  4. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    I think HTM09 is on the right track, and your interest in Hatteras is probably sound. Skip the house; when you return from Kadena, go straight to boat. Pascal's comment about 50-60' being the sweet spot sounds about right, and there's also the additional interior space offered by some designs (MY or CPMY) over others (SF, like ours). I'm guessing a 58' Hatt YF (for example), probably has 4x the interior space we have...
    Wouldn't start with a real "project" boat (aka wreck) though. Believe I'd go for a boat in good shape already; there's enough updating and maintenance you'll want to do anyway, even on that. (I'm my own engineer, and mostly fix or clean something every day, even on a relatively modern boat that was in decent shape when we bought.) Unless upfront $$ is a critical shortage, make it easy on yourself. Start with a good boat, immediately do (or have done) all the initial heavy lifting it might take to make it the way you want it, maintain it from there, enjoy life.
    Yes, there are probably still maintenance jobs you'll want to hire out... but your skill set seems about right to me. Learn more as you go (plumbing, sanitation, wood and 'glass work, etc.).
    Thanks for your service.
    -Chris (USAF, '73-79)
  5. Retire2Cruise
    Retire2Cruise New Member
    I'm at Spangdahlem currently...7 year's total, going back to Okinawa as we were stationed there before here (05-09). I guess the assignment gods are looking out for me and the Family.
    HTM09,
    I'm what's known as an AGE Ranger. Aerospace Ground Equipment technician. I've supported F-15, F-16, A-10...heavies, helos etc. We mainly deal with Detroit diesels and Cummings, but with fighters it was a gas turbine compressor. I personally prefer Cats. If a Detroit isn't leaking, it's out of oil! Cummings would be a second choice...if I couldn't get a Volvo. You're correct, steaks are very pricy on Oki.
    I really love the way a Hatt looks! What concerns me is the fuel needed to run, or the price to fill the tanks....lol! I see guys that speak of spending in excess of $100K annually just in fuel costs! I'm like are you crossing the Atlantic? Diesels could be very fuel efficient if tuned correctly. The Europeans have this pegged! They have cars going over 1000km just on a tank. Granted there's more resistance in the water.
    Chris,
    Thank you for your service and support!
  6. NYCAP123
    Until recently I've been running a 1981 56 Hatt
    The Performance Estimates were:
    Economy 1200 rpm Speed 9.3 kts 12.5 gph
    Cruise 1800 rpm Speed 12.1 kts 35 gph
    WOT 2300 rpm Speed 17.1 kts 70.6 gph
    We generally cruised at around 11 kts, burning about 22 gph. Respectible for a 72,000 lb boat. Granted filling up 1020 gals can put a dent in your Visa card, but it's pretty standard on a boat that sze.
  7. Retire2Cruise
    Cap,
    Knowing diesels, my question is at 1200rpms is there enough load to prevent wet stack or does the manufacturer suggest WOT ever so many hours to properly load the engines?
  8. olderboater
    I don't think WOT comes into the recommendations at all, especially on older engines. Running at cruise does. Taking Nycap's numbers then run 6 hours at economy mode (9.3 knots) and 3 minutes at cruise, then you'd cover 61.85 nm and use 92.5 gallons of fuel so .67 nmpg or 1.50 gpnm.
    Certainly a single engine trawler is going to consume less. 2 nmpg would be reasonable and a 6 knots or so some would approach 4 nmpg. Just using 2 nmpg at the same 9.3 knots then you're talking 30.93 gallons for the same distance. That's a savings of $150-180 for that day. There are other cost savings to be associated with a trawler and a small single engine as well.
  9. ranger58sb
    Chesapeake Bay, USA
    Reasonably easy livin' at 9 kts.
    Probably even slightly better with slightly newer 4-strokes (Cats, Cummins, whatever).
    We do what OB suggests: putter when we can (but with op temps in the recommended range, easily enough accomplished), run at cruise briefly -- usually toward the end of each leg.
    Unless we're in "a hurry" due to unavoidable weather or whatever.
    1200 RPMs is enough load on ours to run in the recommended temp range; even anything above 800 RPMs works, once we get there.
    -Chris
  10. NYCAP123
    Not sure about mfg recommendations, but these old Detroit's are work horses. We had them on several crew boats I ran, and we just did what we did. Lots of idling and slow speed work and long hours at 1900rpm. (I almost never bring a boat to WOT though.). On this boat we did most of the running, days on end in places like the Erie Canal, at about 1200rpm, naturally I'd blow it out when possible, but a leaking oil pan gasket also kept us slow as well. I figure that a 30 year old Detroit has gotten every kind of abuse possible already and survived.
    I'm old school, not an engineer, and run way too many different boats / motors to know everyone's recommendation. So I run 80% when possible, and try to get there at least 1 hour out of 8 when possible. Private boats don't have set practices and routes like military and commercial ships though. I used to work for one owner who knew nothing but WOT on his 1050 MANNS.:eek: That's why an engine survey is always part of a purchase. You'll seldom run into maintenance records like you're used to.
  11. Pascal
    That 56 is the newer wider hull and burns a little more fuel at hull speed compared to the older 53 or 58 which will burn about 9gph at 9kts instead of 12gph. Personnaly I ve never undestood why you d want to run at those in between speeds and the numbers say it all... Increase speed by 30% and burn almost 3 times more makes no sense
    9 Kts is a very comfortable speed, less noise, less Heat, fewer worries ...
    I run a 70 footer with electronic cats and unless the owner or charter guests are in a rush we keep it under 10kts and 18gph.
    So to answer your question if you don't mind going slow a bigger diesel boat will use a lot less fuel than the typical 35/39 foot gasser.
    As long as the engines stay at operating temp the slower speed isn't an issue
  12. Capt Ralph
    Getting back to your original thoughts and post. Anybody and everybody should have a chance to explore and enjoy aqua space. Find a controllable niche you can afford and go for it. Some of us cant afford it but were still here. Stretch your legs and enjoy.
    Oh the other hand I have to say something about (air) pilots operating a boat.
    From F4s to 767s (real old to more painful), pilots are the most difficult customers. Please consider some water does collect in your bilges and it is o k. Please apply the same set & drift attitude when driving between day markers. And it's o k for any motor to drop some oil in the pan.
    Oh and besides the best pre ride (pre flight) checks you can make, stuff still happens,,, it's a boat, not an Air Bus.
  13. Norseman
    Norseman Senior Member
    Hmm, HTM09 flew F-4s and I am a 767 pilot.
    You talking about us?
    Real old to more painful?
    Right on.:D:D:D
  14. Capt Ralph
    Luv you guys. But pilots can be a pain.
    My best customer (Bless him) flew Sabers. Quiet, whisper voice, never a bad word, always a smile.
    Let one thing go wrong on his boat and his wife (Bless her also) would rip you a new one and around the block so the next boat yard could hear what was happening. She taught the navy correct vocabulary and how to vocalize. I worked extra hard to keep his bilges clean and HER happy.
    BTW, I'm a phantom fan.
    One of my instructors (not planes) was a hot shot in repairing the gun pods,, on the line....
  15. Capt Ralph
    Sorry, Now I'm drifting from the OP.
    ,rc
  16. Kafue
    Kafue Senior Member
    Gold Coast Australia
    This is an interesting thread...Fighter Pilots! Hmm, built a few homes for them......interesting characteristics. Even when they turn commercial. One thing they have in common, got to be careful now because some are prob on YF, they are perfectionists. To the inth degree.
    rcrapps, no comment.
    No complaints though, paid their way! We still friends too.
    As to the OP, good advice from all here.
    Pascal has the size right, 55' is a lot of boat if it is not a convertible. However, I find it very telling that some of the most experienced and knowledgeable members on YF are not going to retire on bigger boats, instead suggesting trailerable type vessels.
    Says a lot about what these guys have seen in the way of money being spent on our passion.
    So with that in mind I tread respectfully when I say, go for it! Tomorrow is too late.
    If I had your background and training i would NOT hesititate on buying a 58 Hatteras Yachtfish or similar. Take your time and get the best available.
    Fuel costs: one of the least costs on my annual budget.
    There are a lot of good boats to choose from, enjoy!
  17. K1W1
    It might surprise you to know that at the other end of the business when loading 100 times that amount that the fuel suppliers don't normally take Visa, it is done mostly on credit settled by invoice once you are an established customer with a broker.
  18. NYCAP123
    No surprise at all. Most large transactions are done that way, and in fact I'm old enough to remember when almost all credit was handled that way in the days before Visa, M.C. and Unicard:(. Also, the limit for what some companies will accept on a card is lowering as the banks raise the % they take. Just used the term Visa for literary convenience.
  19. K1W1
    When I first started on yachts nearly all bills were paid by folding green stuff for the most part.
  20. NYCAP123
    Yep, we're old. :D
