Click for Westport Click for Nordhavn Click for YF Listing Service Click for Northern Lights Click for Mulder
84 Lazzara performance numbers
Discussion in 'Lazzara Yacht' started by Pascal, Aug 4, 2016.
  1. Capt J
    Your speeds are amazing and I looked at the specs. It is larger than it appears in the picture. My personal thoughts are it's not well suited for the American market which prefers the FB to overhang the aft deck all of the way and more FB space that can be enclosed, but you could probably build them that way if a customer wished. What price point do they come in at.
  2. AMG
    We better leave this discussion out of this thread, but you are welcome to see the boat at FLIBS in a couple of months!
  3. Pascal
    I don't think it s a fair comparison... It's like comparing a Ferrari to a jaguar saloon. Carbon fiber, IPS, small flybridge. Different market
    Don't get me wrong i love the looks and style. Now the 80/84 Lazzaras are a few inches beamier so I don't see how they d "fit"'in the delta
    Seems to me the delta would be going against pershings and sunseekers not your average American market MY
    we need a big open galley here in the US, this is where everyone hangs out... With a big dinette.. People here call it a country kitchen. Yet when we re done the galley is separated from the saloon. Makes sense
    And FIVE staterooms plus two crew
    Overhang and shade over a big aft deck? A must
    Then the flybridge. Most buyers here want a BIG flybridge. In our case for professional reasons the buyers wanted a skylounge, and it s big ! But the open part behind is as big as the delta
    But again it's an unfair comparison as it sports car vs saloon. Different markets
    Except in this case the saloon is like an XJR. It can, to some extent, play sports car even if it won't quite keep up on a track... :)
  4. olderboater
    I agree that the comparison doesn't make sense, but the Delta is actually 3" beamier from what I've found. Also it's longer.
    Otherwise I would say there are things I like about both boats and things I'm not personally fond of. That's the way it is with most boats. Not a lot of perfect boats out there. I haven't been on either of the two specific boats.
  5. amgscrap
    amgscrap Member
    boca raton
    I also think it is impossible to do a strict comparison. Each has its own buyers.
    Unfortunately, unless you are buying used, Lazzara is no longer an option.
    The Delta looks like a great boat. The IPS is a great system. I don't know much about carbon fiber, my only concern being how easy it is to repair. Unfortunately, the gelcoat guy is a regular with me.
    From a personal perspective, the only two negatives as to the Delta are its strict Scandanavian design and the Fischer Panda generators. I am sure to others the Scandanavian design is great, I like the Italian look. I had Fischer Panda's on two boats. While they are light and compact for me they were totally unreliable. I am sure that can be changed on the Delta.
  6. mike Hartley
    mike Hartley Member
    nj
    Hi Pascal,
    Im looking at an 80 ft Lazzara...with MTU power...have any fuel burn rates at slower sppeds? So far how have you liked the Lazzara and what do you think of her overall?
    Mike
  7. Pascal
    The 80 and 84 are very similar, with the 84 Lazzara added crew quarters aft so all 5 stateroom could be used for guests.
    On the 84 with C32s we burn 20 gph at 1000 rpm doing around 10.5 kts. Thats the best slwo cruise, obviously if you try going an extra knot your fuel burn increases exponentially
    So far it s been about a year and a half, we ve put about 600 hours on the boat and very few complaints. The worst being the design of the lazzarette bilge pump setup which has a very small sump which refills from the water in the hose. As much as i hate check valves, i ended up adding one. I also added a back up rule 3700 in there
    Another minor gripe is the saloon and galley air handler drains which do not have enough slope and clog easily. Something many builders seem to screw up...
    Nautical Structure davit and platform. Nautical structure service is teh worst. Lazzara built a fibrglass cover on the davit boom to integrate it in the superstructure design, pretty slick looking but easy to chip the fiberglass if not retracted i the right sequence.
    Lastly, the light system is a little complex. It is mostly 24v AC (transformers) with relays to switch some lights to 24v DC if AC power is lost. Works well but a little complex. Makes upgrading to LEDs a littel challenging as not all LEDs work on AC, requiring adding AC-DC converters for some led fixtures
    But altogether, these are minor details... the performance and fuel economy is very impressive, as mentioned earlier in the thread. Sea keeping is a bit subjective and hard to quantify, similar hatteras probably handle rough stuff better but altogether the performance and economy are worth it The boat handles very well in close quarters, with easy access to lines etc.... i often handle the lines and dockig alone if the crew is busy with guests.
  8. captainwjm
    captainwjm Senior member
    Miami, FL, Cape Elizabeth, ME
    Pascal, just wondering; do you go 10 kts on the crossing, or just in the islands?
  9. Pascal
    It depends. We crossed last Friday and ran 22kts from Miami to Cat, quick stop to clear then across the bank. At NW channel light we slowed to 10kts all the way to Staniel. We left at 7am and dropped anchor at Big Major at 1am having used 750 USG
    Sometimes we do all or most of the trip at 10kts.
  10. captainwjm
    Thanks. We'll be doing that run in early June.
  11. mike Hartley
    mike Hartley Member
    nj
    Pascal
    Thanks for that.... were thinking on the 80 Lazzara and appreciate the insight. Making a jump from our 50 ft...should be fun. Were planning some runs to the Bahamas...once we decide. I'll look you up for sure!
