Click for Delta Click for Cross Click for Perko Click for Mulder Click for Furuno
77 ChrisCraft 360convertible (paragon) trans.
Discussion in 'Chris Craft Connies, Commanders & Catalinas' started by wmclements, Sep 6, 2011.
  1. wmclements
    wmclements New Member
    Daytona Beach, Florida
    Port side trans. Shifts smooth into forward, shift lever rotates correctly to stop mark when put in reverse but doesn't shift. Shaft turns very slow if you increase power. Mechanic says it has to be removed to check if can be repaired.....please, any feedback
  2. ED Dennis
    ED Dennis New Member
    Chicago Calumet Yacth Club
    I have a pair of Paragon 3.0 to 1 Transmission from a 46 Roamer steel hull. contact me if interested.
    Your slippage may be from a simple o-ring leak in the shift assembly 1 hour check and fix on top of the trans.
