Click for Mulder Click for Furuno Click for Abeking Click for Northern Lights Click for Mulder
1991 Carver 33AC electrical panel access
Discussion in 'Carver Yacht' started by dabluzdude, May 26, 2016.
  1. dabluzdude
    dabluzdude New Member
    Alabama
    I need to replace a circuit breaker. The breaker panel is located behind a smoked plexi-glass sliding door. The problem is that the screws on the left side of the breaker cover panel are not accessible, because the door won't slide far enough to allow access to them. The door handle hits the wood frame before the door slides far enough. It's been suggested that I might be able to lift up on the door enough to remove it from its track, but I havent had a chance to try it yet. Can anyone say for certain how this door is removed, or at least slid far enough to allow access to the screws? thanks in advance, enjoying the forum.
  2. MAV
    MAV New Member
    Ontario, Canada
    Lifting to clear the bottom track is how many of them work. If yours has protuding handles, removing them may allow you to slide the door further. Some will also have a stop screw in the bottom or top track, removing this screw will also allow the door to slide further.
  3. dabluzdude
    Alabama
    1/4" drill bit and 3 holes later... problem solved.
