Click for Burger Click for Mag Bay Click for Mulder Click for Westport Click for Burger
1988 Post 46-Buy or Not?
Discussion in 'Post Yacht' started by Boomer, Oct 16, 2017.
  1. Boomer
    Boomer Senior Member
    Seminole
    Thank you for your advice and thoughts.
  2. Boomer
    Seminole
    Roger that!
  3. Boomer
    Seminole
    The smoke is black from what I am told.
  4. ReelPlumber
    ReelPlumber Member
    Fort Pierce
    To get really good info on the DD's there is a forum http://boatdiesel.com/.
    You definitely do not want to overheat a DD but as long as you keep good maintenance on them, clean fuel, filters, oil, etc. they are work horses. If you don't over prop them, run them hard, and their not too high of HP you should be able to get several thousand hours on them.
  5. Boomer
    Seminole
    Interesting...several thousand hours of use...as in 2000 hours before overhaul? I have been told 692's are time bombs so I am a little hesitant...I believe these in particular are 550 hp each....good information to digest!
  6. ReelPlumber
    ReelPlumber Member
    Fort Pierce
    I think that most of the "Time Bomb" issues were with the 635hp DDEC's. If propped correctly (not over or under and should be 2300 - 2350 rpm at WOT), maintained properly (oil, fuel, heat exchangers, filters, zincs, etc.) , and not ran hard all the time it should not be a problem to get 2000 hours.
  7. ReeLeeHooked
    ReeLeeHooked New Member
    Taunton, MA
    She looks like a fine Vessel. I agree get a Detroit Diesel Mechanic involved and best of luck to you. Happy Sailing.
  8. Boomer
    Seminole
    How do I remove it?
  9. Boomer
    Seminole
    Thank you for your input...
  10. My Affair
    My Affair Member
    Mystic, CT
    David
    Hi, What size inverter would run all of that load and what are you running for batteries? Where did you install the water maker?
  11. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    I would count on a full rebuild of that engine (that needs a top overhaul). So, that's around $18k plus count on $5k-$10k for all that goes into getting the engine out and then back in and additional things that are found during the process. Overall, it's a really great idea to find a boat that is already running perfectly and has the upgrades you want.
  12. Boomer
    Seminole
  13. baltimore bob
    baltimore bob Member
    Baltimore, Maryland
    That's usually low compression. Better factor in the cost of a rebuild.
