Click for Burger Click for Glendinning Click for Furuno Click for JetForums Click for Mulder
1977 42 Flybridge MY w/Gas Engines
Discussion in 'Bertram Yacht' started by Craig Rinkel, Jul 24, 2015.
  1. Craig Rinkel
    Craig Rinkel New Member
    Michigan
    I am considering buying a 42 FBMY that is powered with Marine Power 502 400 HP engines with 1200 hours. Does anybody have any experience with gas engines in a boat like this? I'm looking to do some cruising and day trips. Maybe 150 hours a year. Is this an efficient power package? Does the boat handle ok? How long until I have to replace the engines?
  2. chesapeake46
    chesapeake46 Senior Member
    Everyone here will tell you to get a survey, a GOOD survey before anything.
    My friend used to look at boats with me prior to purchase and he would ask me if I wanted him to tell me what I wanted to hear or tell me the TRUTH. Meaning, don't fall in love with the boat until survey is complete.
    I always felt 40 feet was the cut off for gassers.
    Also, Bert's are harder to keep on top than a flatter bottomed sport fish, another reason for diesels.
    Lastly, 1000 hours was about when you would do the top end rebuild of a gas engine.
    Do you know if there has ever been any work done on the engines ?
  3. Craig Rinkel
    Michigan
    Thanks so much for the feedback. I will get a mechanical inspection and survey before I do anything.
  4. Eroc
    Eroc Member
    CT
    Personally I wouldn't want a boat of that size and weight powered by gas engines. That engine doesnt make peak power until 5k rpm, one thing to remember is that it's always running up hill. Big blocks don't like to rev and they are thirsty, as Chesapeake said be prepared to rebuild the top end. There are so many 42's for sale I would look for one with detroits
  5. Capt Ralph
    Can you offer a mfg or type. Flat bottom or V hull? Draft / planing? Fast or slow or dock queen.
  6. olderboater
    Bertram. Deep V. Semi-Planing. Top speed when new 22 knots, cruise 14. Draft 4'0". It's in the Bertram forum section, hence my guess. Maybe a little faster with the larger engines it has.
    And to quote from a write up on the boat.
    With her proven deep-V hull, the Bertram 42 can handle sea conditions that keep other motor yachts her size in port. Several engine options were offered over the years. Standard 330hp gas engines—a poor choice in a heavy 42-foot motor yacht—will cruise at 14 knots and reach 22–23 knots top. Twin 335hp Detroit 6-71 diesels deliver a 16-knot cruising speed (18–19 knots top), and optional 435hp 6V71 diesels cruise around 20 knots.
    Same hull as the Bertram 42 Convertible.
    Efficient power package, No. Diesels would be a lot more efficient in terms of fuel consumption. Should cruise faster than the published 14 knots with the 502's. I would guess about 16-18 knots. 502's are near the end of their life expectancy at 1200 hours usually. Pushing that boat with gas inboards is A LOT to ask out of them. Some people do get 3000 hours out of them, but running at cruise in a 42' Bertram MY puts one heck of a stress on them. The previous owner might have run at hull speed most of the time though.
  8. Capt Ralph
    The hp to weight ratios make the gas engines & performance look better on the sales brochures.
    Hence why you can note the big diesels are not as fast.
    For HP to fuel consumption, the diesels are close to half. Still not quite as fast as the short lived gas engines.
    Time for some serious soul searching;
    How many hours do you REALLY believe your going to operate each season?
    How long are you going to keep the ship?
    In this an investment or known money pit?
    Other thoughts to consider;
    Rebuilding and replacing long blocks is a part of your future, Can you swing a wrench?
    I am a Bertram fan. I can tell you that this deep V takes a lot of Horse Power.
    Loaded with fuel, ice, provisions and a boat full of people, You may not see all of the speed you did light.
  9. RT46
    RT46 Senior Member
    there is the other side to consider with a gas powered boat of this side.
    If only using the boat under 100 hours a year and happy with 7 knots, the gas boat will be cheaper to maintain and service in the long run.
    I bet you could drop in a long block replacement BBC for around $3k.
    I do agree that a 42' boat is the upper limits for sure on gasoline power.
    a short season, limited hours, northern lake boat with this power could make sense.
  10. Capt Ralph
    Other than diesel boats require more oil, larger oil filters and larger raw pump impellers;; I don't see any cheaper to maintain on the horizon for a short lived LBC.
  11. Capt J
    Compared to 6-71's I don't think so. Add up the price of a set of exhaust manifolds and risers every 5 years, plugs, wires, cap, rotor, coils, fuel pumps, etc etc.....Replacing or rebuilding the gas motors every 1000-1500 hours, I'll take the 6-71's and their cheaper fuel and much lower fuel consumption anyday in a boat like this. A set of 6-71's will usually go almost 10,000 hours.....
  12. Capt Ralph
    Skippy J bet me to the punch line.
    I am glad he did. I may have forgot some of those items.
    Again, were back to my #8 post on serious soul searching.
    If it's a low hour, mostly slow speed, dock queen or apartment (chicks dig scars and boats), then the gas option MAY work.
    We don't mean to bust bubbles here. Many of us have fond memory's of our first, second gas boats.
    Were all mostly diesel for many reasons.
    We have learned (sometimes the hard way) a few things thru the years and trying to save some of your time and money.
    That's a heavy, deep V boat.
  13. olderboater
    I would imagine with the OP located in Michigan, there are a considerable number of gas boats in the area. My first five boats were all on an inland lake and all gas like every other boat around them. However, in this particular boat, there was only one reason it was gas and that was initial cost. In the initial price today the difference would be $40-50,000. I'm sure it was significant when that boat was built. Of course the difference remains significant at resale too, so don't think it's a great deal because it's less expensive than comparable with diesel. It should be less.
  14. Craig Rinkel
    Michigan
    Thanks Everybody, great advice all! It is a Bertram. The price is $30K less than a comparable boat up here. Most boats for sale in this size seem to have Cat 3208's or DD 6-71's so I was pretty suspicious of the 502's. I have rebuilt BBC's before and the engine room is huge compared to my last express cruiser. I have never been around a diesel yet. The cost of diesel repairs and my ignorance of them makes the gas attractive. I really don't like running 4-5K RPM all day, so I am going to keep looking. Thanks again.
  15. chesapeake46
    Years ago I looked at a 42 Post with gas engines. I thought the engine compartment was a dream come true. You could put a bunk on the outboard side of each engine ! Fortunately I had a mentor that set me straight on the fine art of internal combustion engines and their possible limitations.
