Click for YF Listing Service Click for Cross Click for YF Listing Service Click for Nordhavn Click for Ocean Alexander
1976 35 Viking 4 blade Propellers.
Discussion in 'Viking Yacht' started by jetawave, Sep 13, 2015.
  1. jetawave
    jetawave New Member
    Newtown, CT/Bridgeport, CT
    I have a 1976 35' Viking with 350 HP each engine. Carburetor motors. Has any one ever switch to 4 bladed props? and if so what diameter and pitch did you find worked best
    Any info. is greatly appreciated.
    Thanks, Jetawave
  2. RT46
    RT46 Senior Member
    I did the same thing on the same boat and switched back to the 3 blade because they were faster.
    the 4 blade got me on plane faster, but the cruise speed was lower
  3. jetawave
    jetawave New Member
    Thanks, RT46. I appreciate you help. Do you think that by increasing the pitch on the 4 bladed would of increased you cruise any ? Do you happen to remember what the Diameter and pitch was of the 4 bladed? Thanks, Jetawave
  4. RER
    RER Senior Member
    Newport Beach CA
    3 blades or 4 blades, the diameter and pitch remain the same. Better know what you're doing before you start adding pitch and load on those old gas motors.
  5. RT46
    RT46 Senior Member
    Not certain, but my best recollection is that the wheels were 19x18 three blade w 1 3/8 shaft.
  6. dsharp
    dsharp Senior Member
    lake jackson, tx
    You drop the pitch by 1" when you go from a 3-blade to a 4-blade prop.
  7. RT46
    RT46 Senior Member
    yes, that was what I had.
    but I changed back to the 3 blades, the three blades had overall better performance.
  8. Viking76
    Viking76 New Member
    glen cove, ny
    19 X 19 4 blade DQX Dynaquads, 8.1L (385 HP)
