Click for Abeking Click for Westport Click for Abeking Click for Nordhavn Click for Ocean Alexander
Aluminum Boat Hull Blisters
Discussion in 'Technical Discussion' started by gooddeal, Apr 16, 2004.
  1. gooddeal
    gooddeal Guest
    Any recomendations on reducing or eliminating corrosion blisters on aluminum hulls?
  2. diesel
    diesel New Member
    Victoria, B.C.
    If you're refering to paint blisters then this is the result of poor paint prep or a scratch which wasn't touched up. If you're talking about the small corrosion pitting on bare aluminum, this is usually the sulphur in diesel fuel coming from the exhaust. I used to have a partially painted Eagle Craft which suffered from both, it was 13 years old mind you. There isn't much you can do about either, apart from the paint touch ups. We already use low sulphur fuels and paint prep on a large surface is quite difficult to get perfect. A good painter can repair these, with proper blending techniques, without costing too much.
  3. JHA
    JHA Senior Member
    unpainted aluminium oxidizes naturally and the surface "corrosion" is actually protection from serious damage. As for painted aluminium blisters are in one word - unavoidable.
  4. trouty
    trouty New Member
    West Australia
    I dunno you guys...sheesh...sometimes I worry about you crew!
    A blister under the paint with white powder in it is a sign of galvanic corrosion.
    Google search it! - eliminate the source & problem solved - fail to do so & kiss ya alloy hulled boat goodbyee, in double quick time - just sit & watch it turn to white powder and blow away in your slip in front of your eyes! :p
  5. diesel
    diesel New Member
    Victoria, B.C.
    Galvanic corrosion occurs when two exposed dissimillar metals are together in a solution. That means this will happen below the water line only and if the metal is EXPOSED. If you have a blister under your paint and there is no scratch or chip exposing the metal then the painter did not etch the paint which cleans off the natural coating that JHA was talking about. If you have any sort of blister above the water line is it chemically imposible for galvanic action to happen because the metal is not exposed in a solution. If you do see a white powder or gel growing from exposed aluminum UNDER THE WATER LINE, then yes, that is dangerous levels of galvanic action.
  6. Qocean
    Qocean New Member
    Coast of Maine
    Hey
    trouty are you the same guy that post on BoatDesign.net?
    Some pretty radical thinking. Just fell upon it on a google search. My dad is a marine consultant, concentration in project management, but also design, so it sort of sparked my interest.
  7. trouty
    trouty New Member
    West Australia
    Q Ocean,
    I'm glad to hear, your not one of these lads who shows up in a loud V8 panel Van with wide white lettering tyres, painted fire engine red with yellow and orange flames painted down the bonnet, past the hole where the supercharger sticks up into it's scoop - with a mattress in the back and a picture / mural of Conan the Barbarian painted down the side - and a sign that says "If you see this van a rockin don't come a knockling, don't laugh - your daughter might well be inside!" - and proudly announces "he's here to collect my daughter for a date".... :rolleyes:
    Sadly and as much as I hate to admit it, it was probably exactly that which attraced my daughters mother to me all those 25 something plus years ago, (much to her parents chagrin at the time) but all the same I KNOW what a ratbag I was at that age and what evil intentions were always foremost on my mind, so these young whipper snappers don't fool me for even a second! :D
    OK - to your questions then...
    One question I had about aluminum is:
    From the start of galvanic corrosion how long does it take to compromise the yacht structurally? If not properly addressed at the start?
    How long for compromise is a variable – how long is a piece of string type question. And of course the answer is it depends.
    It depends on a lot of things.
    1.Where on/in the hull the galvanic corrosion occurs
    2. What electrolyte the hull is immersed in
    3. What currents are involved?
    4. What grade Alloy is used
    would be a few of the major issues that could influence the correct answer to your question.
    To expand upon them a little.
    1. What part of the hull is eaten away might influence structural integrity mor4eson than a different part. If it’s a critical part from an engineering viewpoint that takes a lot of load bearing of compression / tension or torque stresses then earlier hull failure might be expected than if some attached deck hardware is the victim that gets corroded away…
    2. Depending upon the level of salt in the water (Eg Freshwater lake/river, or Estuarine Tidal Inlet, or open ocean may dictate the efficacy of the galvanic cell created and hence the rate at which the metal is corroded away.
    3. Where on the elemental table of elements the various metals involved in creating the galvanic cell are found, in other words their relative nobility (willingness to give up/lose electrons to other less noble metals) will help determine the rate at which the most or least noble metal in the galvanic cell is eaten away. Addition of things like stray current from an adjacent boat in a dock or poor/leaking earth shore power installations on the dock or adjacent vessel, will also have an effect on the rate at which galvanic corrosion occurs.
    4. Again the Grade of alloy (percentages of other more or less noble metals in the alloy mix) will also determine the rate at which Galvanic corrosion occurs. Marine grade Alluminium alloys (AMS Alloys) (Alluminium, Magnesium & Silicate) vary in percentages of Magnesium and Silicate in the alloy. More makes it more ductile and malleable which is great for pressing and stretch forming complex compound shapes/curves and planing strakes but bad in terms of accelerated rate of galvanic corrosion due to the presence of greater quantity of lesser nobility metals in the parent alloy., Conversely the higher marine grade alloys have less of these higher / lower nobility metals – but don’t handle bending / folding etc any where near as well – and require special press arrangements of large radius press bars into V break blocks to achieve a bend without cracking / breaking the plate.
    That’s roughly how it works off the top of my head.
    I have heard some arguments about the benefits of steel vs. aluminum, but most of it was relevant to cost, not long term performance.
    Any opinions?
    Both have their advantages and disadvantages like any boat building material.
    It’s interesting that a lot of the professional fishers etc that are moving away from GRP / FRP hulls toward metal are building commercial fishing boat hulls from plate alloy. This seems to apply up to say the 70 ft – 125 ft range roughly…
    But, those with large working trawlers etc all seem to go steel hull.
    No doubt they all have their reasons – it may well be to do with weight for trawlers with extended booms (and sometimes full nets weight as well) – that steels heavier and gives a better GZ stability curves line (the boats more stable and less likely to roll over!).
    Steel when you build with it you have to allow a lot more thickness for a relatively long life while allowing for the termites (rust) to eat maybe half or more of it away before it becomes structurally unsafe.
    Alloy on the other hand pretty much corrodes and forms a protective layer and self protects (if you don’t allow galvanic corrosion / electrolysis to eat it away first). So you don’t have to allow that extra thickness for longevity that you do with steel.
    Steel due to it’s superior strength could actually build an equivalent strength vessel to alloy with about 1/6th the thickness – BUT it would rust away in weeks or months so we see much thicker steel being used to allow for the high attrition rate in marine use of steel.
    They both have their individual properties that suit them to certain uses and skippers pick which one best suits their needs when selecting a hull material to build from.
    Cheers!
    P.s. Yes M = Δ T rules, coz trouty says so!!!!
    Tom beardens one of natures gentlemen QOcean and a very very clever physicist.
    Time is the answer (and you if you live thru whats comming) will very likely get to see all of it revelead within your lifetime - the dawning of the new age..."the time of the end", or more correctly, "the end of time!" as we know it and the end of it's dominion of our lives.
    I hope you make it to become a time lord along with the rest of us! You havent that long to wait, Dec 12th 2012 isn't that far away. (Specially NOT for a time lord!) ;)
    Use the Power QOcean - the hidden 3 space energy trapped (compressed) within Time....
    More cheers!
    P.p.s He -who hasn't switchd on html scripting in my posting profiles? Carl???
    Mass Equalls Change in Time, was what was sposed to show M = Delta T. Durn Puters! :confused:
  8. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
  9. Shay
    Shay Guest
    Hey there,
    I know this is an old thread, but this seems like the right place to ask.
    I'm considering buying an older aluminum yacht and it has some bubbling above the water line on the sides of the cockpit. There doesn't seem to be any blisters on the main part of the boat, paint looks good from the aft deck forward. The swim platform is also chipped, but no signs of corrosion, I'm guessing it can be removed and repainted fine, but the blisters in the hull really worry me.
    They are pretty sizable, but not have not split open, so I can't see if there's white powder or not. It's just on the sides of the cockpit, about 3 or 4 half dollar sized blisters. I love the yacht, but don't want to pay (a tidy sum on a boat this size) to haul it out for a survey if those blisters are a good indication that the structure has been affected and I shouldn't waste my time moving forward.
    So, anyone with experience in older aluminum yachts, can you answer a couple of questions?
    Would this be an indication that the bottom will have corrosion issues?
    If it is Galvanic corrosion, about what does it cost to fix?
    And, will the integrity of the boat still be good or compromised after the repairs?
    Thanks for all the help in advance. =-)
  10. Capt Ralph
    First,
    MFG and year is important is asking about alloy boats.
    We could use that hint as lots of us know what was used, when for lots of hull models.
    We know what hulls to avoid.
    Next, Your term Galvanic corrosion is used to often and mostly incorrectly; Stray electrical underwater currents remove less noble metals toward stronger metals, think Diode, while under water.
    The #4 post above is in error.
    This is not the case in this picture but still an important question for submerged metals (see below).
    This picture shows a paint/fairing blister that happens when moisture gets between the alloy and finish. Also if not prepared correctly on last paint job attempt. There will be a white jelly under that blister when cleaned out.
    I have worked on alloy boats 50 years old with minimal issues, then others with later finishes 2 years old worse than this.
    I would say this was fair to poorly re-finished within a few to 5 years. AND, will probably come back again.
    Think if your hand covers an area, each hand represents 3 hours of repair correctly, not including finish coat.
    I see 7 hands x 3 hours x $100 average tech charge. In your pic $2100.00 to CORRECTLY fix, not including final color cover.
    Did you just gasp??
    Now the bottom.
    Bottom plates require audio sounding.
    You hire a surveyor, He has a tech (You Pay for also) to clean many hull areas of paint and fairing and measures with his fancy audio sounder, how thick the bottom plates are.
    Plate starts at 3/16" to tin foil thickness. His report will tell you where these spots are (after you pay him).
    Aluminum is the less noble material in the water. Galvanic corrosion does apply here. The thinner the remaining plate vs original material (pending mfg spec) tell the proper surveyor the condition of the wet hull and strength left.
    Then, if you purchase the boat or not, these bare spots on the hull bottom have to be re-coated, at your expense.
    The better previous owners will offer past surveys with these measurements from their files. A boat without these records I would be cautious of.
    You still interested in a cheap boat??
    Alloy boats have their own benefits and maintenance challenges. Non are cheap to repair.
    If properly maintained thru her many years (rarely) it may be a good boat if maintenance is continued.
    I would not recommend an alloy boat to a novice.
    I have managed Strikers and Roamers. I spent well the owners money.
    The end results were fine boats.
    You still have your breath? Call an insurance agent. Can you insure her?
    My personal old boat is plastic. She still looks fine (at a distance) but the bottom is just as thick and strong as new.
    So, fill us in on what she is. Fill us in on what your shopping for.
    Fill us in on your experience or just another NFG.
    I would enjoy a picture of you expression after the phone call to your insurance agent.
    :D
  11. Shay
    Shay Guest
    LOL at the last few comments. I have years of boating experience, so I'm not a total noob, but this is my first time buying my own. Not sure what NFG means, but it doesn't sound pleasant. o_O
    It is a 1980s Broward. I have no real knowledge of aluminum boats, so I'm leery, but this brand is know for high quality and I love the look of her compared to Hats (which I'm also looking at a smaller hat, which is glass which I do know more about). I didn't want to go this large, but she just really is amazing, and I can swing the expenses. If I go Hat, I'll go much smaller.
    So far, insurance agents have been harder on me for smaller boats that I could drive myself, so I am opting for a larger that I can hire a captain, which seems to have made things omg so much easier lol (albeit more costly in all aspects).
    As for what I'm shopping for, something to do extended (like months on end) cruising with space to work (no, I'm not quitting my job to be a youtube star lol) and I like long range cruisers the best for this. I'll be on it 90% of the time and living and working from it, so I better really love it. =-)
    I work a lot and this seemed like a great way to have an adventure and still keep my business going.
    Thanks for the answer... I really appreciate the words of caution and advice and I will take them to heart. I don't trust the brokers as far as I can throw them :D
  12. Shay
    Shay Guest
    PS, no I didn't gasp. lol Somehow nothing surprises me anymore when it comes to the cost of boat ownership lolol
    and, yes, I did talk to insurance agents and they can insure it if I get a captain. I do plan on getting my captains license, too, but the insurance demands I always have someone on board with me no matter if it's a small 35' =-(
  13. Capt Ralph
    One of your best comments.
    There just a few exceptions, A few on here that can help if needed.
  14. Capt Ralph
    So, an old Broward.
    In S FL??
    Run away now..
    Post the web listing here. Some of us may know the boat.
  15. Shay
    Shay Guest
  16. Capt Ralph
    Re-Powered with 8V92s.
    I can see lots of issue there you do NOT want.
    PNW is salt water also. Bring her around and it thaws out,, Hang on ...
    At that price, and all, yes run.
    However, I can put you into a sweet Hatt CPMY that is turn key in N FL.
    I see you just PM'd me. Details there.
  17. chesapeake46
    chesapeake46 Senior Member
  18. Shay
    Shay Guest
    Thanks Chesapeake! I'd read that thread before and it made me tear up seeing that lovely boat cut to pieces. They are lovely boats.
  19. chesapeake46
    There was a Burger in a slip behind me for a few years.
    It was a '62 and 63' long.
    It had 8V-92's that started before the engine would make 1/2 a turn.
    No smoke, purred like a kitten.
    It was a really pretty boat and a nice somewhat updated interior.
    Really nice traditional motor yacht lines to her.
    But
    The paint was in the same bubbly condition.
    The teak decks were shot, no brining them back.
    The brightwork was failing bad and the patchwork repairs on that were making it look even worse.
    The one time I was in her engine room I found engine oil, presumable from leaky DD's, all over the place.
    It could be had for little money for a boat of it's caliber but still, 60 years old.
    I was tempted for about 1 minute.
    Then I looked over at my baby and just like the old TV commercial, I thought, " I think I'll keep her"...
  20. Capt Ralph
    I get into other boats from time to time.
    Sometimes I think smaller and faster.
    I either found a sister ship or the same 44 Striker I used to manage 30 years ago.
    I started talking about it with da wife,,, Uh Oh,,, I got that look; Baker Act and forgotten, I will rot somewhere else.
    Naw. Ole tried and true can not be beat.
    She (and Josie) will keep me aweigh from other hussy hulls.
    I think my baby boat just wants some attention.
    Currently replacing stb main, forward PTO seal. I replaced that seal 16 years ago.
    While the HE is off, new hoses also.
    Should be an easy job. But my back is 16 years older also.
    Shay likes this.
