Click for Perko Click for Abeking Click for Burger Click for Walker Click for YF Listing Service
The NEW Oceanco Y702!
Discussion in 'Oceanco Yacht' started by YachtForums, Feb 1, 2006.
  1. Oceanco's NEW Y702!
    Following in the footsteps of its predecessor, the Y701, which has received extensive build coverage by YachtForums, Oceanco is proud to unveil the NEW Y702! Another cutting-edge creation by the dynamic design duo of Nuvolari & Lenard, the Y702 is slated to splash in the summer of 2007.
    Although there are striking similarities between the two 700-series yachts, there are dramatic differences in features. The 702 upholds the bold, angular look of its sooner-to-be-built sibling, but with smoother contours and some refined design elements. It’s not surprising the 701 would have a successor; the design has been so well received it prompted at least one owner to build another. At first glance, the 700’s look so much alike, one might wonder if Oceanco was building production superyachts, but these are very different builds. The most distinguished difference is the Y702’s new heli-pad. In contrast to the Y701, the Y702 will have shortened upper-deck overhangs, allowing a full size heli-pad on the main aft deck. But this isn’t just any landing pad… the heli-deck is actually a pair of solid sliding panels that uncover a swimming pool!
    There are many interior changes as well, including a new skylounge gym and a dedicated dining area. Nuvolari & Lenard designed the interior of the Y702, whereas Pinto designed the Y701’s interior. Four deck plans have been provided below for a closer look and a brief set of specs follows.
    The ocean NOW has two best addresses...
  2. The Grayscale Rendering...
  3. Salon Rendering...
  4. Master Suite Rendering...
  5. Short Specifications:
    Length Overall: 82.00m/269.04ft
    Beam max: 14.20m/46.59ft
    Max. speed:approx. 18.5 knots
    Range: about 5,500 nautical miles at 14 knots
    Accommodation: 1 Master suite + 2 VIP + 2 double guest cabins + 1 twin guest cabins
    Crew: Captain’s cabin + 1 engineers cabin + 2 officer’s cabins + 10 double cabins + 1 quartet cabin
    Material: Hull – Steel, Superstructure - Aluminium
    Engine type: 2 x 3492 KW MTU 16V 595TE70
    Fuel capacity: 245 tons
    Water capacity: 80 tons
    Classification: Lloyds register X100 A1 SSC Yacht (P) MONO G6 XLMC UMS – MCA
    Naval Architect: oceAnco
    Exterior Designer: Nuvolari & Lenard
    Interior Designer: Nuvolari & Lenard
    Delivery: Summer 2007
    Oceanco Yachts
    Gildo Pastor Center - 7
    rue du Gabian
    MC 98000 MONACO
    www.****************
