Click for Mulder Click for Delta Click for Westport Click for Cross Click for Northern Lights
Feature: CL Yachts CLB88 Motoryacht
Discussion in 'CL Yachts' started by YachtForums, Nov 28, 2019.
  1. CL Yachts CLB88 Motoryacht
    The CLB88 is a motoryacht built with CL Yacht's design philosophy in mind; blending a long, illustrious history in ship building with the very latest in materials and technology. CL Yachts extensive expertise in resin-infused composites is highlighted on this build, integrating carbon fiber reinforcements into the lamination schedule, allowing the yacht's weight to be significantly reduced while strength and rigidity are increased.
  2. Built on a floating framework, the interior of the yacht is separated from the hull and support members to minimize vibration that is transmitted to the living areas. By integrating tankage with the hull, the boat's rigidity is increased and a double-bottomed safety zone is created. The architecture & materials combine to bring about a robust build that is also fuel efficient.
  3. The combination of efficient lifting surfaces, a quick responding hull, generous freeboard and bow flair all ensure the CLB88 is ready to run offshore. Available gyro and/or fin stabilization systems will further ensure a sedate ride, while a CZONE system monitors tankage and primary functions. A generous 3,000-gallon fuel capacity keeps the joy of long-haul explorations firmly on the table.
  4. From the mind of Milan-based designer Jozeph Forakis, every element of CLB88 has been conceived to exceed the desires of the modern yachting enthusiast with every square inch of the CLB88 designed to maximize space and utility.
  5. With one of the largest flybridge decks in its class, the upper deck is equipped with a refrigerator, ice-maker, outdoor grill, and ample seating. A large hard top shades this space while panoramic views of the surroundings blues ensure a breathtaking backdrop.
  6. With 270-degree views from the stern, the aft deck becomes a living space with a generous sized settee, dining table and wetbar making the aftdeck an extension of the salon.
  7. The CLB88 takes on the challenge of opening up the salon to become one with the environment. Large windows bathe the living spaces with light and low-back modular furniture is utilized for flexibility.
  8. The intimate arrangement of the galley brings the cook and captain together while still keeping an eye on course. CL Honeycomb cored furnishings and composite foam-backed stonework help keep the weight down while still delivering solid, durable surfaces.
  9. The lower helm is modern and minimalistic with a bench seat to stretch out on long legs and grab handles, just in case.
  10. From a near beam-wide dining area to enough galley space for multiple family cooks to argue, each element of the CLB88's interior is thoughtfully considered to unite everyone onboard.
  11. The modern and minimalistic approach is continued below with a master stateroom that relaxed and welcoming. Warm wood veneers, understated luxurious furnishings and soft goods all work harmoniously.
  12. Ensuite bathrooms are ultra-modern and equipped with finishes and amenities normally found on superyachts. A clean color palette and plenty of light help create an upscale but do-your-business ambiance.
  13. Four staterooms are featured on this boat. The master is full beam amidships with not one but two equal-sized VIPs forward and another guest stateroom with twin berths to port. The equal-sized VIPs will be a highly attractive prospect among buyers in this size range.
    Cheoy Lee Shipyards
    2019 SW 20th Streeet, Suite 208
    Ft. Lauderdale, Fl 33315
    www.clyachts.com
